Best way to send 300Mb
MadAmos
What is the best way to send a bunch of files 20-30 Mb each 300 or so total to my Brother in law in another city. I can't use e-mail because there is a 20Mb restriction. Is there a good free ftp software you can recommend I do have access to storage on line if it helps.
Amos
You are going to be limited by your upload. At any rate, you could install Hamachi on both of your computers, enable sharing of the folder where the files are located on your computer, have the bro-in-law goto My Network Places, and he should see the folder there and he can open it up and copy all the files over. If you don't want to do that or are limited by your upload too much, mailing the CD sounds like a good idea to me.
Thanks Old Hippie, :cookie: the Rapid share Link looks like it will work great I will probably give it a go his evening. I know I could send a cd but this is a good excuse to learn a new way of doing things... and who knows I might find something that works better. 😀 So I would still like any other input on people send larger files just for future reference.
Amos
