- Jan 6, 2004
- 632
- 0
- 76
Just got a Barton 2500+ going to run it for now on the stock AMD HSF that comes with it.
whats the best and easiest way to clean off the square of thermal compound on the HS?
my ideas are either
Just scrape it off with a knife,
heat and scrape,
use some kind of oil like goo-gone and scrape
anyone have a good way ?
do I have to let it sit for a while if I use goo-gone to let the stuff get out of the HS ?
my ideas are either
heat and scrape,
