- Sep 13, 2001
- 53,676
- 6,557
- 126
i have a screw that is used to screw in drivers to a speaker cabinet. on the underside of the speaker cabinet there are t-nuts that the screws screw into.
well when i was screwing the screw into the spot, the t-nut became dislodged after the screw was screwed into it.
and now for some reason the screw is like stuck in the t-nut and i can't get one off of the other. i've tried holding the t-nut on the underside of the driver (the speaker holds 3 drivers so i removed the one next to this driver to get my arm in there) and i can't turn one or the other because they are kind of stuck.
it is tight inside of the speaker case as well and there is the driver magnet close to where this is happening, so it is hard to reach down in there. i tried holding the t-nut with some needle nose pliers but had no luck. as soon as i turn the screw the pliers come loose.
there is probably like 1/4 or 1/5 an inch, if that, of wiggle room where i can pull this screw up from the hole it is supposed to screw into, before the back of the t-nut hits the inside of the speaker and i can't pull it up anymore.
anyone have any ideas how i can get this screw out? i don't mind if the screw is ruined in the process as i can just get another one.
