Originally posted by: Kibbo
It works out ok, if you have a cast-iron skillet. Salt and pepper it, rub oil into it.
Pre-heat the pan, really hot. Slap it in there, maybe a minute. DO NOT MOVE IT. Flip, again for a minute. Finish it off in an oven, 500 degrees. Not long, maybe a min or two each side. I assume you know how to tell doneness. Let it rest 3-5 mins off the heat, before cutting or serving. Deglaze the pan with a bit of red wine, add a bit of beef-stock in the bottom, and you get a jus, if that's your thing. Reduce the crap out of it. Not needed on a sirloin, in fact a bit of a waste IMO. Tenderloin's flavour is mild enough that you may want this.
Originally posted by: Hammer
Best way to pan fry a 1 inch thick steak?
get your SO to do it![]()
AH! You want to minimize the steak movement as much as possible. Continuously flipping the steak is a wonderful way to remove all the juice from inside the steak where you want it to outside the steak where you don't want it.Originally posted by: amish
you can cook a steak on just a pan i've done it many times. lightly oil the pan with olive oil. let meat get to around room temp and put your spices on it. place steak and a piece of bacon in the pan. flip steak continuously so that it will not get seared too much. the bacon will give the steak a different flavor and it will keep the steak moist from the grease. the pan should be set at medium heat.
Originally posted by: MX2times
Here is what I have decided to do per all the good info
Marinade to room temp with worchester sauce and italian dressing, salt, pepper. Pan one minute both sides @ med-high to sear. Oven 500 till done. Roasted asparagus on the side
I'll post pics.
I'll post pics.
Marinate!? OOOHHHNOOOOOOOOO!
whats wrong with a short marinade?
What cut of meat is this steak?
I'm sending the meat-squad if you say New York strip or T-bone.
