- Oct 9, 1999
- 72,636
- 46
- 91
Are you currently paiting the ceiling or do you have any of the ceiling paint left?
If so one option that works wonders is to tape the edge on the ceiling, then paint over the tape with the ceiling paint. When it's dry paint your wall.
The ceiling paint will seep under the tape and fill any voids with the correct color so when you come through with the wall color there won't be any bleed-through.
Ceiling is already painted. House was built in late 2005 -- all the ceilings are off white, the walls are a whitish/cream color.
I got this short flexible-handle brush... should allow better control along the corner edge where the wall meets the ceiling.
