Best way to learn Visual C++ (tutorials, books)?
darkjester
Hi all.
I want to get into some Visual C++ (or Visual Basic or Visual J++ -- my sister's university hooked her up with VS6 for free 🙂). I was doing some web searching for a tutorial to teach me the language(s). There are a TON. So I figured I'd ask you guys for any success (or horror) stories with any particular tutorials (online or downloadable). I'm not exactly rolling in dough, so shelling out a few hundred dollars for classes is out of the question... but buying a book or two isn't.
So, what are the best tutorials and/or books out there for Visual [anything]? There are so many of both, it'd be infinitely more helpful to know what has worked for you guys.
Thanks a mil! 😀
If you have no programming experience so far it would probably be better to get a very basic C or C++ book and learn that before trying to learn MS specific stuff, and avoid VB like the plague it'll just get you into very bad programming habits.
One you understand C/C++, it'll be pretty easy to learn a new library (like MFC for Windows or QT for cross-platform GUIs). VC's debugger is pretty nice but I never liked VC's IDE for doing GUI things, but maybe you will.
I guess the only advice I'm really giving is to avoid the MS specific crap for now, learn the real language before you delve into MS' version of it.
<< If you have no programming experience so far it would probably be better to get a very basic C or C++ book and learn that before trying to learn MS specific stuff, and avoid VB like the plague it'll just get you into very bad programming habits.
My fault for not mentioning it: Actually I have a lot of C/C++ experience, so it sounds good if you're saying it'll be easy to learn. It's just that from what I've heard, there are the quirks and other "funny things" about VC++ that differ from regular ol' C++ (what they are, I don't know). So in essence, maybe I'm looking for something to quickly lead me from using C++ to Visual C++ as painlessly as possible.
Any book or tutorial suggestions/recommendations are very welcome and appreciated! Thanks! 🙂
The MSDN help is usually really well documented, I found my way around with it most of the time. Sorry I don't have any links/books for you, but I'm pretty much exclusivly Linux now and as such won't touch VC again =)
Since you are choosing MS platforms, an attempt to learn the basic underlying APIs will be well worth you time. This can give you a stronger understanding of how Windows applications work within theirselves and others.
Petzold is an excellent author and steps you through the basics without blowing smoke.
