Best way to kill sex drive completely?
alien42
12,717
3,118
the best way to kill any womans sex drive completely is trident.
maybe you can find the female version of yourself.
lord_emperor
1,380
Build a machine that causes prostate ejaculation on command, fire it off a few times when entering the proposed situations.
TridenT
16,800
45
That doesn't do anything. I can stay hard forever and that won't end the hormonal chaos either. Masturbation does nothing.
OCGuy
27,224
36
Sounds like you have champagne taste on a beer budget. Learning what "league" you are in will help you get over the fact that you are never going to finger whatever hot chick you have a crush on.
You need to start talking to females who you actually have a chance to bang.
TridenT
16,800
45
Actually, I realized it when I was five, but these things called hormones don't care what the hell I think.
schneiderguy
10,765
52
Just curious, post a picture of the female that you'd consider the bare minimum of attractiveness.
OCGuy
27,224
36
Getting some action and maybe even falling in love with a chick who is a 5 instead of a 10 still satifies sexual desire. As soon as you are old enough to go to a bar and do the old "2 o'clock sweep", you will find this out yourself.
Do you cry every time you see an Italian sports car go by?
illusion88
13,164
TridenT
16,800
45
Not really. And since I don't really fall in love with 5 out of 10s nor make friends with them... ain't happenin'.
Cry? No. Die a little inside? Yes.
OCGuy
27,224
36
So some part of your brain that controls attraction, is over-riding your natural and hormonal urge to mate, even if it isn't the most desirable mate out there.
If this is the case, and evolution is to work properly, this will be removed from the gene pool by you not reproducing.
The only wild-cards are alcohol and sex-crimes...
