I just got a 2007 Toyota Corolla S which has the standard CD player in it, pretty much identical to the one in this picture. What is the best way for me to hook up my iPhone 3GS to it? There is no tape deck (so I can't use a tape adapter) and as far as I can tell, no AUX in either. My requirements:
(1) Music: the sound from the iPhone needs to be outputted through my car's speakers.
(2) GPS: I use my iPhone for turn-by-turn navigation, so it needs to be mounted in a way I can easily see and reach it.
(3) Phone: I want the calls to go through my speakers
Do any FM transmitters actually work well? Or do I need to replace the stereo/receiver? If so, with what? I'd like to spend < $50, but if it's something really nice, I'll go up to $100.
Update
Ok, after doing more research, I have it narrowed down to 2 options:
Sony Xplod CDX-GT130 CD Receiver: $97 including shipping, in-dash kit, wire harness and coupon
Cheapest receiver I could find that had an AUX input, was made by a decent brand, and had good reviews. I'd connect the iPhone to the cigarette lighter for charging and to the car speakers via the AUX input.
Sony CDX-GT630UI CD Receiver with iPod Control: $120 including shipping, in-dash kit, wire harness and coupon
Similar to the receiver above, except it also has a USB input that will both charge the iPhone and play its audio over the speakers. This is a slightly more elegant solution as I'd only need a single wire. Unfortunately, I've read that the sound from phone calls does NOT go through the iPod cable, so to satisfy my 3rd requirement I'd still have to use the AUX input... I wonder how the stereo reacts with both iPod and stereo cables hooked up?
If not for the phone call issue, I'd probably be willing to dish out the extra $20 to only have to deal with a single wire. However, that may be a deal breaker and push me towards the first solution.
Update
