Best way to have an egg drop 15 feet and SURVIVE
Discussion in 'Off Topic' started by Bulldog13, Nov 13, 2006.
  1. Brackis
    Brackis Banned
    Nov 14, 2004
    2,863
    Take a piece of paper... make areally thin cone shape out of it.... insert egg in top and wrap area where eggs is sitting in bubble-wrap.
    When it falls the paper compacts, and it tips over from a very low height.
    Follow?
    I just came up with that in my head without reading the thread.
  2. YOyoYOhowsDAjello
    YOyoYOhowsDAjello Moderator<br>A/V & Home Theater<br>Elite member
    Aug 6, 2001
    31,192
    12
    I was supposed to say that :(
  3. NYHoustonman
    NYHoustonman Platinum Member
    Dec 8, 2002
    2,642
    When my friends and I had to do this, we created a pyramid using cardboard (only along the edges, with each piece bent about 90 degrees to make it stronger), and suspended the egg in a lightly cushioned container (again made of cardboard, and some padding) from each corner of the pyramid. Worked like a charm, although it took longer than other peoples.'
    We could only use tape, cardboard, and some kind of cushioning (don't remember what), however.
  4. Ika
    Ika Lifer
    Mar 22, 2006
    14,268
    I had one too (though technically). She taught at a nearby college, and taught at the high-school part-time (this was AP Biology).
  5. Bulldog13
    Bulldog13 Golden Member
    Jul 18, 2002
    1,646
    Thanks guys !
  6. SilthDraeth
    SilthDraeth Platinum Member
    Oct 28, 2003
    2,633
    I never got to do the egg experiment.
    But for the bridge experiment, I got to do that one.
    My class however, had to build a bridge within a certain budget using tooth picks and wood glue. My teacher assigned value to each bundle of tooth picks, and each little cup of glue we used. The bridge had to be supported by a flat piece of wood simulating the ground, and there was a hole in the middle of the "ground" to hang the weight through.
    My bridge won, and I got to engineering stage a little late. I believe I could of built an even stronger bridge, but I will never know, we still where the strongest for the class. This was 7th grade for that project.
  7. Brackis
    Brackis Banned
    Nov 14, 2004
    2,863
    Did the same thing in 4th grade, had a lot of fun with it. Like real builders I falsified expense reports and stole toothpicks and glue when the teacher was not looking, but in all didn't have any reenforced areas and was still under budget outside of cheating.
    Ended up holding somewhere around 50 lbs on crap when the weight was attached from the base of the bridge, and then after that gave out the weight was placed on the top of the bridge and it held over 65 lbs. Prolly the most enjoyable thing from elementary school I can recall, besides maybe a simulated adventure across the country on a wagon train that was done over the course of a month.
  8. blueshoe
    blueshoe Senior member
    Mar 6, 2005
    414
    Some people did that in my class back in high school. It actually worked. They didn't even use bubble-wrap.
  9. thescreensavers
    thescreensavers Diamond Member
    Aug 3, 2005
    9,928
    I got a box full of cotton foam but the egg in bubble wrap and at the bottom of this said box had springs at the bottom and sides. survived 20 foot drop until 30 feet it fell upside down do remember to put some waghit so it flips corectly
  10. DeepBlu
    DeepBlu Senior member
    Aug 17, 2004
    245
    Inside a bag of popcorn works well.
  11. SociallyChallenged
    Mar 22, 2002
    10,487
    Hm, this reminds me of the cornstarch + water videos I've been seeing lately. I wonder if that would work....
  12. slvrsol
    slvrsol Member
    Sep 14, 2003
    85
    probably the best idea when i had to do this was styrofoam to hold the egg and a bunch of straws stuck into that it so it would just softly bounce off the ground...extremely light weight as well.
  13. Rastus
    Rastus Diamond Member
    Oct 10, 1999
    4,706
    Drop the egg and LIVE CAREFULLY.
  14. SoulAssassin
    SoulAssassin Diamond Member
    Feb 1, 2001
    6,140
    take a 12oz soda can, fill it halfway with a resin, insert egg, fill completely with resin. Let dry. Damn near indestructible.
  15. CKent
    CKent Diamond Member
    Aug 17, 2005
    9,020
    1) Drop egg with no protection
    2) Sue farmer for millions over defective egg
    3) Pay some broke college kid $50 out of your millions to devise a way to drop it 15 feet without it breaking
