I have a v2 Linksys WRT54G wireless router that gives a middling signal across the inside of the house and a very weak signal through the brick wall to my deck.
What is the best AP/card setup I should consider for swapping out what I'm using now?
Actually, I'm planning on using the WRT54G just as a router and turning off the wireless and then attach the new AP (wireless router?) off a better located ethernet jack.
 Facebook
Facebook Twitter
Twitter
