best way to get src for SETI to compile for UNIX
mgpaulus
Hi,
I am attempting to assimilate a pretty much idle development box that is an HP 9000/899 dual proc machine running HPUX 11.00. I can run the hppa-10.20 version, but I thought it might be a tad more efficient if I could recompile the source under 11.00, using 64 bit code. I thought maybe I would ask here to see if anyone knows, before I go traipsing all through the SETI site.
Thanks.
Yep, source code is closed. Maybe if you beg enough the SETI people will compile a new version for you, but the 10.20 version should work pretty well...
