Best way to get rid of line-wrapping problems?
bubbasmith99
479
Argh! My stupid school email will only work on a web-based system that always throws line wrapping off. Whenever I draft an email in notepad (do it there in so I can save in case something catastrophic happens and I lose my work) or on the web based system, it turns out that the line wrapping is always completely off. I should learn from my mistakes and do all my email drafting in MS Word, which is the only program that copies the email perfectly in terms of line-wrapping when I copy and paste it into the text box on my web-based email.
Okay, anyway...
[THIS IS THE JIST OF WHAT I NEED TO KNOW, IF YOU WANT TO SKIP MY EARLIER RAMBLINGS]
So if I have a huge amont of text with tons of screwed up line wrappings, is there a funciton on MS Word or some other program that will go through that text and format the spaces/indents/line breaks correctly so that paragraphs are put together properly?
Does anybody know what I'm asking?
Thanks for the help if anybody can provide it.
