Best Way to get an audio tape onto a CD?
bob4432
11,727
46
i need to get an audio tape onto a cd. i will be using a tape recorder into the mic in on the sound card. what software that is free do i need to make it a .wav so i can burn it to a cd?
thanks
Aug 16, 2001
22,505
4
Check out GoldWave. It's shareware with some restictions but I've had good luck with it.
Just record one continuous Wav file and cut it in smaller pieces.
Good luck.
TSDible
1,697
I haven't done this in a while but...
I did used the program built in to EasyCD at the time. It would record a wav file and then detect silence and automatically cut the tracks. I think the current burning software packages still have features similar to this. I will check my nero tonight. Warning: Don't try this method with something like Pink Floyd "The Wall." You will get more tracks than you can shake a stick at. :)
Otherwise, you could get a free audio editor like audacity and cut the tracks yourself.
Personally, I use a simple stereo DJ-type tape deck that I got from the Shack years ago plugged in to my line-in.
I know it isn't much, but I hope that helps.
bob4432
11,727
46
thanks for the info, in fact i don't need to cut the songs into different tracks, just one lone song.
