Best way to get a keyboard gleaming white again?
Quad
1,222
i've been using my keyboard for about 8 months without cleaning it. before it was shiny white, now it's sort of an off-white colour. it's obvious that its dirty, but what's the best way to get the casing/keys gleaming white again? anything in particular to use? or will warm/soapy water do just fine? (after taking the keyboard apart of course :p )
thx in advance
sohcrates
7,949
yep, soap and water works wonders...just give it adequate drying time and it'll be fine
my roomate used to soak his in the bathtub every now and then...but that might be a little extreme :)
MiExStacY
740
what ever you do dont be stupid like me and use brake cleaners to try and make it super white,because it does get super white but other then that it peels the plastic out of it and the letters on the keyboard will vanish
blstriker
1,432
Buy a new one. j/k
They have some type of clean like windex, pledge, etc, that comes in a blue bottle that's designed for plastic electronics like tv's, stereos, computers. Should clean your keyboard pretty good.
Mats
408
Propanol will make it look brand new, it might rub the lettering off the keys if you rub long enough, so be careful.
jamarno
1,035
Radio Shack Cleaner-Degreaser should be safe on plastics, but for less money there's CRC Electronics Parts Cleaner at hardware and auto parts stores.
Don't use soap and water on a keyboard that contains a flexible circuit board because they will become trapped between the two layers of plastic.
Noriaki
13,640
Just buy a new one ;) They are what $10? $15?
:p
But if you have a rather expensive keyboard, you can get electronics cleaner from radio shack or any similar store.
The Sauce
4,741
34
Just give it a good licking. Alternately you can put some cream on it and let the cat at it...their tongue is coarser than ours.
Mitzi
3,775
We still talking about keyboards? :D
Moohooya
677
Stick it in the disk washer. No, I'm not kidding. Make sure the dishwasher is clean and there are no other dirty things in there. (I stuck it in with the plates once and got food suck behind the keys!)
Then, give it ample drying time. You might even want to open it up to allow it to dry faster.
Don't blame me if it never works again. Every now and again I do get failers, but I figure the $15 for a new keyboard is nothing considering the time I save.
Diable
753
I put mine in the dishwasher. Just unscrew the top part(with the keys)and put it in the dishwasher before you go to school or work and when you come back it should be dry and shiny white again.
khtm
2,089
I used to live in res at university and every week or so some dumbass (or myself) would spill a beer or rum&coke or anything else possible onto my keyboard.
The next day I'd soak it in the bathtub for an hour, take it out and let it dry off on my heater. It was good to go within a day! I must have do this at least 5 times.
-khtm-
whitelight
3,505
i use rubbing alcohol and just scrub off the dirt. it takes a little scrubbing, but it gets clean.
VTrider
1,358
<< since i can get a nice keyboard for $5 i never clean mine... just get a new one every 6 to 12 months >>
I love it! Good old American thinking :)
Turbo55
925
Rubbing alcohol. Works fine for me. :)
*I feel like the idiot who bought an $100 keyboard, but at least it was from Microsoft. :cool:
TOraptor
68
disamntle the ah heck
unscrew all the goddam parts and put all the plastic in the tub
and then when u feel the whiteness is back..
just paste it all together..
hihihi
Dude... if u dont wanna try this .. get some decent cleaning solution and a not so sharp knife.. wrap a cloth around it.. not you best shirt ..
and paint the ah heck with the solution..
goddaaammm what an ideeeaa
HalfCrazy
853
I use a cleaner called 'Plexus' on my keyboard. Shines and cleans the keyboard in just one step. People that play's paintball uses this stuff to clean there paintball mask-lens.
nortexoid
4,096
buy a black one?
spray paint it white...white it out...use water and some sort of cleaner...illuminate it until it appears white....etc.
