Best way to dispose of a body?
mjrpes3
1,876
Grind up the bones and spread it around your garden... excellent fertilizer.
You might want to plan ahead before you do the deed and sound proof the basement. This will quiet the grinding equipment and not disturb neighbors.
Remember, planning ahead and getting everything prepped for the big day makes the whole process much smoother. You'll enjoy peace of mind and the overall stress of the job will be much lower... now that's thinking about you!
Freshgeardude
4,506
Originally posted by: chuckywang
First, be smart from the very beginning. Pulverize all teeth, burn off fingerprints, and disfigure the face. Forcing a DNA test to establish identity (if it ever comes to that) might introduce the legal/forensic hurdle that saves your ass down the line. An unidentifiable body can, in a pinch, be dressed in thrift store clothes and dropped in a bad part of town where the police are less likely to question it. I don't reommend that disposal method, I'm just saying an easily identifiable body is an even bigger threat than the opposite.
Assuming you have it inside a house where you can work on it a bit, the first thing you want to do is drain it of fluids. This will make it easier to cut up, and slow decomposition a little bit. The best way to do this quick and dirty is to perforate the body with a pointed knife, and then perform CPR on it. Cut the fronts of the thighs deep, diagonally, to slit the femoral arteries. Then pump the chest. The valves in the heart will still work when dead, and the springback of the ribcage can put apply a fair amount of suction to the artria. Do this in a tub. Plug the drain, and mingle lots of bleach with the bodily fluids before unplugging the drain to empty the tub. This should help control the stench of death, which would otherwise reek from your gutter gratings. Do everything you can to control odors. Plug in an ionizer, burn candles, leave bowls of baking soda everywhere. Ventilate the room in the middle of the night, but otherwise keep it closed. Keep the body under a plastic sheet while it's in the tub.
If you want to bury, I recommend seperating the body into several parts, and burying them seperately. For one thing, it's easier to dig a deep enough hole for a head than for an entire body. this reduces your chances of being discovered while you are actually outside and digging the grave.
That is the one thing you can't do inside the doors of your house, and represents a vulnerable moment you want to keep brief, under 2 hours. Do it between 3 and 5 am. It's also less likely for someone to call the police if their dog digs up some chunk of meat, than if they dig up an enitre body. They may assume it's an animal carcass disfigured by decomposition, and leave it alone or dispose of it. It's also more likely that the dog will consume all of it before anyone knows the difference. A whole skeleton is another story. You can cut a body into 6 pieces faster than you think. It's not much different than boning a chicken, but it takes more work, a big knife, and time. A hammer will be useful for pulverizing joints or driving the knife deep where it doesn't want to go. Anyway it's wise to crush as much of the skeleton as you can along the way. It will aid in making the body less identifiable for what it is as it decomposes.
Don't return to the same site 6 times for 6 burials.You'll attract suspicion from anyone nearby, and you'll wind up placing the body parts close enough together to be found by any serious investigation. Put them in plastic bags with lots of bleach, and store in a freezer until you have enough time to bury them all.
Depending on what tools you have available, you may find that you're get really good at deconstructing the body. You might prefer to slowly sprinkle it down a drain without leaving your house. This avoids the long-term risk of discovery associated with burial, and the overwhelming supply of bacteria in a sewer accellerates deconomposition, whil e providing a convenient cover smell.
Truly grinding down a body takes a lot more work, and you run the risk of fouling your plumbing and calling in a plumber. So don't try it unless you know how to clear bones and meat out of a drainpipe. A good food processor can be useful. But don't over-use it, or power drills or saws. They're noisy and they attract attention. And forget the kitchen sink. It's better if you actually remove one of the toilets in your house from its base, which will give you direct access to one of the largest sewer pipes that enters your house. Follow any disposals with lots of bleach and then run the water for 5 or 10 minutes on top of that. And plug that pipe when you're not using it, to prevent any sewer gasses from backing up into your house. Usually, a U-trap inside the toilet does that for you.
sounds like you have done that at least 3 times
Daverino
2,004
Launch the body out of a nuclear submarine somewhere in the middle of the Pacific.
Or, as an alternative, the 'rocket to the sun' method is always a sure bet.
coloumb
Don't do it in Canada - they don't need a body to convict you. ;)
And chuckywang - sounds like he's a real life version of Dexter. :)
Miramonti
28,653
100
Many bodies can be removed by simply reducing temperatures for a sustained period of time, particularly bodies of water.
Quiksilver
4,725
Beat me to it. :thumbsup:
herkulease
3,923
Drain blood, chop up body in small parts, wrap it up in biohazard bag. People less likely to go digging in there. head to local university with a science program. over a small period of time throw each part into their biohazard waste. . That stuff gets taken to an incinerator to be burned up. Do it during the day with students walking around. Less likely to draw attention from campus police when you sneaking onto campus in the middle of the night. during the day they'll just think your the lab ta or some lab tech cleaning up.
JTsyo
12,038
1,135
If you hold a funeral and have a body buried, do they ask for ID or anything for the body? Or does the undertaker just take care of it?
sourceninja
8,805
65
My step day says he owns a construction company just so he can hide the bodies in septic tanks.
BoomerD
66,355
14,768
That probably depends on the jurisdiction...BUT, let's just say that there have been occasions where 85 lb. grandma's casket seemed AWFULLY heavy...maybe because she was on top of someone else...
People have used undertakes for centuries to hide bodies. All you need is to have one who's "deeply in your debt" to make it work.
The enzymes would do a pretty good job disposing of the flesh. Not sure how long it'd take to digest bones and teeth.
Big construction projects are indeed a good place to "hide that which needs hiding."
Usually though, to do it right, you need an accomplice or two...then you have more dammed bodies to hide. :roll:
