Kelemvor
Howdy,
I know of 3 ways to delete restore points and am wondering if there's a reason to do it one way over the other.
1) Using Disk Cleanup (cleanmgr) you can go to More Options and click the 3rd button to delete all but the most recent restore point.
2) Going into Computer Properties, you can check (or un/recheck) the box for Disabling System Restore.
3) You can manually go into the System Volume Information folder and delete everything in there.
I would think 1 or 2 would be the best option since you're at least letting Windows do the deleting but is there really any benefit to doing it one way over the other? And is there any way to automate one of those via a batch file or anything?
We have PCs that were setup 3+ years ago and the restore folders gets huge with all our software updates and things. Even though we have System Restore turned off, it still fills and we have to un/recheck the box or do something to clear them out to save disk space.
