- Dec 11, 2006
- 7,851
- 6
- 81
I'm just wondering if anybody else has found a way to cool the southbridge. Motherboard is an EVGA 790i FTW. My MCP temps have been insane, and my computer was crashing out this weekend from the heat.
I have tried removing the thermal padding and replacing their heatsink compound with some better non-conductive heatsink paste, which dropped the temps about 5-7 degrees C but I'm still sitting at about 75C / 72C MCP/SPP under load which seems rather ridiculously hot for MCP / SPP.
For comparison, my CPU is running about 37C idle, max at 58C load after running OCCT overnight. The "motherboard" sensor typically shows 38C in everest.
I know that the factory heatsink is definitely pulling heat from the chip since I can get close to touching it and it's really hot. Only other option I guess is to contact EVGA and see if I can get an RMA, but I'm not sure they would be willing to accept a return over something that isn't technically not working.
