Originally posted by: SagaLore
I highly recommend
St. Bernard's iPrism. The annual license is less expensive than websense, and it comes as an appliance instead of just software. It can work as a transparent bridge - just connect the firewall inside interface to the external port, and the internal port to the switch. The reports are nice, you can schedule them, and you don't have to enter a proxy in everyone's browser, i.e. they can't bypass the proxy. Their newest release includes malware categories. You can also create multiple profiles linked to active directory groups to give different departments/users different access.
After looking at their site and speaking with them on the phone, their product looks to be exactly what I would like to implement. The only thing is the price...
$2195 for the initial hardware purchase, then $1495/year for a 100 user license and another $300 for maintenance (american currency).
Not sure if my bosses will go for it, but I'll see what they have to say anyway.
Thanks for the link!
Okay now call up the leading web filtering vendor,
Websense, and see how much it will cost for their software solution. And also give
BlueCoat a call, which is another appliance based solution. Comparing iPrism to them in your proposal might justify the cost, because it's not as much as you think.
In the past I looked at setting up a Linux server with Squid, but then you'd need to purchase a SmartFilter subscription which comes to about the same cost fo the iPrism.
edit;
Now do you use anything for antispam? Because I could make a recommendation there too...
