Best way to connect a RAID
Is it best to use the primary and secondary bus connections on the motherboard or is it faster to go primary and slave with one cable?
I'm thinking 2 cables 2 drives 2 connections to the motherboard would be faster. Am I wrong?
If I have to drives of different sizes can I setup a RAID and it would just be the smallest drive size?
This is all eide.
Thanks
Fastest would be 1 drive to each IDE channy, no slave stuff..... 😉 (You're correct)
RAID will set up and run according to the smallest/slowest drive in the array........
