- May 23, 2002
- 16,928
- 8
- 81
I have an old 27" TV that I have a PC hooked up to. The TV has standard S-Video and Component connections. I currently just use an old video card with an SVideo port on it and it works fine but the quality is obviously not real great during videos (TV Shows and movies).
Would I get a far better picture if I got some other type of video card that could use the component connection? If so, is there a card out there that anyoen could recommend? My budget is "as cheap as possible" since it works fine the way it is but I'm just looking to up the quality a bit.
I've seen some VGA to Component converters and I've also see the port that kind of looks like an SVideo port but with extra connections in it that you can get an adapter cable with that on one end and the component connectors on the other but I don't know anything about them.
Thanks.
Thanks.
