fustercluck
Heyas, i got a new monitor (NEC FE2111SB) and it's tricky to clean, it has a special sort of screen. Can't use windex or anything with alcohol, and just using little dabs of water doesn't seems to work well. There's some smudges on the screen that i can't get rid of. Here's what the manual says about cleaning it:
So not sure what to use, i assume they'll have what i'm looking for over at Office Depot or Comp USA or something.
A special coating is provided on the glass (CRT) surface of this monitor to
reduce a reflection and static electricity on the glass surface.
Due to the delicate coating on the glass surface, use a lint-free, nonabrasive
cloth (cotton or equivalent) and a non-alcohol, neutral, nonabrasive cleaning
solution to minimize dust. If the screen requires more than a light cleaning,
apply water or soften neutral detergent with much water directly to a soft cloth
and use it upon wringing water, to clean the glass surface.
CAUTION: The following agents will cause damage to the CRT when cleaning
the glass surface: Benzene, thinner, acid/alkaline detergent, alcohol detergent,
detergent with abrasive powder, detergent with antistatic agent, detergent
for cleaning
