Best way to clean CDs?
Jugernot
6,889
I bought a few previewed DVDs at Blockbuster and couple of them have some scratches and finger prints on them. Anyone recommend a good way to clean CDs? I know you are supposed to wipe them from the inside out, not in a swirl pattern as many do it.
In case anyone cares, you can easily remove the writing "permanent" marker on the disc itself with their numbers, etc. with a simple pencil eraser. Works really well!
Anyway, what is a good way to clean CDs/DVDs? What cleaners to use? What type of cloth? CD cleaning machine?
Jugs
fr
6,408
Originally posted by: FoBoT
i just wash them in the bathroom sink, liquid hand soap, dry them with a towel
Same, but I don't use soap.
HiTek21
4,391
I just use a damp cotton cloth and lightly rub off the finger prints and dirt in an outward motion.
