Best Way to clean Acrylic Window? (and take care of static)
Layzee
107
Hello fello ATers...
I just installed an acrylic window in my case and I noticed that immediately the static from the window attracted tiny bits of dust. What is the best way to clean off the dust and neutralize the static charge? Is there some sort of spray or cleaner I can use? Can an acrylic window be grounded to get rid of the static? I tried using a lint free cloth to wipe the window but the static cling was too strong to get all of the little dust particles off. It's not too much of a big deal, but I figure that if it attracts dust now and I'm not using the case yet, then when I really use it, cleaning the window will be a pain in the ass...
Thanks in advance and yes I did use the search button... :)
fast_eddie
518
A plastics or acrylic supplier in your area should have "Gentle Cleaning Plastc Cleaner with Silicone for Anti-Static/Dust Protection" - I use Sunnyside brand - call 1-800-323-8611 'for more information' - they will probably be able to give you your local distributor OR check your local home-suplly store, Lowe's, Menards, HomeDepot, or whatever is in your neighborhood. This product also helps prevent minor scratches to plastic windows.
