Best way to clean a Sony G400's screen
obenton
2,012
Solvents can harm the anti-glare coating. I use soft tissue, sometimes moistened with water.
medic
I use a mist of water on a soft cotton cloth then lightly clean the monitor. (I have heard bottled or filtered water is better though)
First, I would check out the manual or website for instructions. (call them even)
Pete
4,953
Ditto what the two peeps above me said--Windex or the like is a no-no, as it removes the anti-glare coating on your screen. If plain old water or soap-and-water doesn't satisfy you, then try something like EnDust, which is made for monitor screens.
AMB
2,587
He he, reading the manual is a clever thing...
<< Clean the screen with a soft cloth. If you use a glass cleaning liquid, do not use any type of cleaning liquid, do not use any type of cleaner containing anti-static solution or similar additive as this may stratch the screen's coating >>
<< Don not rub, touch, or taop the surface of the screen with sharp or abrasive items such as a ballpoint pen of screwdriver. This type of contact may result in a scratched picture tube >>
- Who on earth would do that? :Q
<< Clean the cabinent, planel and controls with a soft cloth lightly moistened with a mild detergent solution. Do not use any type of abrasive pad, scouring pad or solvent, such as alchol or benzene. >>
GreenGhost
1,272
What about those wet/dry pads sold by this by catalog companies like Global? Any chance of harming the monitor surface. Well, they are made especifically for cleaning monitor screens.
Pete
4,953
If those are a type of monitor wipe, avoid at all costs--those things streak more than clean. They're totally useless.
