Best way to clean a cardboard box (no, really)
Status
Not open for further replies.
thatsright
3,004
I have a Nikon D800 camera box that was once new and shiny. I noticed there are several hand/finger prints all over the covering of the box. I tired hot water/elbow grease and then some rubbing alcohol. Nothing. The box has a high grade coating suitable for printing the lable on it. Almost like a wraper.
Any ideas?
Crono
23,720
1,502
Orange oil, maybe. If isopropyl/rubbing alcohol didn't do it, though, maybe it's not likely to come off.
zinfamous
111,695
31,043
Are you trying to sell the camera?
If not, I would like to point out that you are weird.
angminas
3,331
26
Dear guy who has "You have some dust on your monitor" in his sig,
Please post in this thread.
Yours in evil,
ATOT
monkeydelmagico
3,961
145
Damon Wayans hosted a very informative show titled This Ol' Box. I'm sure you could google that and get some pointers.
sdifox
99,339
17,542
should come off with damp microfiber towel. try some dish soap if water is not strong enough.
sourn
577
Clean with some rubbing alcohol while leaving it damp, then light a zippo (regular lighter that will still lit) and slowly move it around the box.
Box will look brand new I swear it.
ElFenix
102,393
8,552
lols
Status
