best way to capture video from DV cam and burn later?
Sniper82
16,517
Wanna capture all the video off of my DV tapes. But I don't wanna burn to DVD right now. Whats the best method and format to capture to and to be edited and burnt later on, also that different video editing software will read. I wanna be able to fit at least a hour of footage on DVD.
John
Moderator Emeritus<br>Elite Member
4
There are many apps available. Nero Vision Express works great and it's easy to use.
GullyFoyle
4,362
11
The best format to "capture to", is to keep it in the format it is in now. Use your camera's Firewire or USB port to copy the DV file from your tape to your computer, bit for bit. In this way, you have not lost any details (yet). Always try to preserve the original as much as possible until the last minute is the key to good video processing results.
Here's a link to the DV Capturing FAQ and Myth guide from VIDEOHELP.COM: FAQ They usually suggest some freeware or shareware solutions that you can download and use.
I don't have a DV Camera yet, but if I did, I would probably go back to using Pinnacle Studio. It can do what you need, plus handle all the editing through burning to DVD to will do later. It works great with DV source, version 8 was not so hot with stuff already in MPEG2.
Sniper82
16,517
Don't think I have enough HDD space to capture all the footage to if I go with straight DV format.
