Best way to apply thermal grease?
coredumperror
45
Hi all,
I've had a little experience applying thermal grease to my various Athlon CPUs over the years, but I've always felt that I could do it a lot more efficiently. I've wasted a bunch of Arctic Silver, and could have applied it much more evenly, but I've never really found anything that says how best to do so. So, before I start putting my new machine together, I wanted to ask here what the best way to apply thermal grease is.
I've also got some left-over Arctic Silver Ceramique from a few years back, and I was wondering if I should replace it with some AS5 to apply to my new system. Should I bother?
shabby
45
Some people smear an even amount over the core and put on the heatsink, while others put a rice-sized amount of paste in the middle of the core and make the heatsink squish it and spread it over the core.
I prefer the second way.
Caldenfor
114
I have seen someone use a plastic bag before to spread it around nice and thin. I am not sure what is the best, but I just thought I would toss that into the discussion. Could use non powdered latex gloves? I have no idea, I would stick with the baggy.
Dave
LittleNemoNES
4,142
Dave
I do this.
Use a ziplock bag and spread it around. Use a blade to remove the excess. Your fingers should NOT touch anything.
Waylay00
1,793
I just put a small pea sized drop of it in the center and let the heatsink spread it out.
pkme2
3,896
I use a drop of AS and smear a very thin coat with plastic covered finger. It works for me.
Soul Colossus
62
I'm surprised no one has mentioned the credit card/razor blade method? That gets it the most even. The drop in the middle seems like it would be confined only to the center of the heatspreader.
LittleNemoNES
4,142
Pens1566
13,850
11,523
And where exactly do you think the cpu core is?
erikistired
9,739
the pressure spreads it out nicely. supposed to stop air pockets from forming as well.
RallyMaster
5,581
Originally posted by: snes tor
I do the small rice grain drop in the center... let the heatsink squish it.
some guy asked me the same question the other day...he found applying AS5 really difficult...that n00b
Powermoloch
10,084
4
I've been using the squishing method for a while now. And it never failed me...in both CPU and GPU HSF installations.
VinDSL
4,869
www.lenon.com
I don't know exactly what you mean by 'squishing method' -- but, with my last HSF -- I had to fight like hell to get the $!@%# thing installed.
I turned it this way, and a corner clip came off...
Then I turned that way, and another corner clip came off...
So, I started over again, only to have another corner clip come off -- squishing the grease the whole time...
Eventually, I got this POS HSF on -- on all four corners -- and it worked out okay...
So, this is what I call the "squishing method".
LoL! Is this what you're talking about? :)
erikistired
9,739
i would think he means the grain of rice in the middle method.
cmdrdredd
27,052
357
After a while it will spread out on its own naturally.
