You can use any small sharp object to apply the paint. I used a jeweller's screw driver, the really really tiny kind. I'm thinking a pin would work just as well. I taped the other 3 bridges while working on one, so as not to get any paint on the other 3.
As for removal, any alcohol based spirits should work, ie paint thinner, lighter fluid or isoprophyl alcohol.
