Sorry for the delay, Mikewarrior2...
Oh, I thought 39C was hot
The only other CPUs I've ever paid attention to heat on were some Celeron 300a's that were going 450 at just under 30 usually.
One thing lowering the temp maybe is that I'm running it currently with the cover off the case (so ambient case temp is room temp.) Room temp is around 67F.
I put on about twice as much arctic silver and after an hour or so of the Torture Test it was same as before 39C. Oh, I'm also just running barebones...only card is the video card, not sure if that matters really though.
So I'm safe with 39C then...that's good to know. I think I'm going to try a real thin layer and then a really thick layer and see what happens.
EDIT: Forgot to mention the motherboard...Asus P4T with two sticks of Samsung PC800 128mb RDRAM.
I thought of another thing to mention...Prime95 does not have an option for P4 so I just set it to P3 and 1400 MHz. I forgot to tell Prime95 it was running 1600.
The P4 seems to run around 34-35C at rest btw.
