Best Watercooling Kit for my System
airhendrix13
427
Hi,
The topic summary basically asks my question but, I have an EVGA 680i Mobo inside of a Thermaltake Armor Tower w/ the side fan. I plan on buying and OCing a Q6600 after the price cuts and I feel air cooling w/ my Zalman 9500 won't be enough to hit my desired OC around 3.2GHz and up. I do understand that the G0 version of the Q6600 will be better for OCing but I can't guarentee I'll get one. I also want the kit to be able to cool my 8800GTS, but right now it runs on the stock fan, and I dont know if there is an option available to cool it. This will be my first LC kit because I've had very good air cooling.
So now for the question:
What is the best watercooling kit available for around $200?
Thanks,
airhendrix13
PCTC2
3,892
33
Well, I can tell you the Zalman 9500 won't be enough. My Zalman 9700 could only do 3.6GHz on my E6400, let alone my Q6600. If you want a cheap outlet, get a Thermalright Ultra120 eXtreme, lap it, and thrown 2 Scythe S-Flex Fans on it.
As for water-cooling, if you want to watercool both your 8800GTS and your Q6600 OC'ed to 3.6GHz, you're going to need a custom kit that might need to be mounted externally (you might be able to squeeze it into the bottom of the Armor with a little case modding and casters for the bottom.
Swiftech MCR320 120.3 Radiator 55
MCP655 Pump 80
D-Tek FuZion CPU 65
EK FC-8800GTS GPU 130
Swiftech MicroRes 20
Master-kleer 7/16 ID tubing
That's probably the best set-up for you, for about $350. It's a little more, but the $200 kits won't dissipate enough of the heat to be worth it. An overclocked quad and an 8800GTS put out too much heat for a 120.2 radiator.
Plus, read Aigo's W/C guide. it's pretty good for everything. :). Hear that aigo?
EDIT: I have a similar set-up to yours. Read my thread.
BonzaiDuck
16,748
2,106
Aigo insists that OC'ing a quad-core pretty much means water-cooling, and I won't argue.
PCTC2's advice seems sound, especially for the radiator.
BonzaiDuck
16,748
2,106
If you only want to water-cool the CPU, and your 8800GTS will continue to be your single VGA choice, the HR-03-Plus by ThermalRight is a darned good air-cooler for that nVidia card.
My stock temperatures on the BFG 8800 GTS 640mb were pushing 70C during game-play with an idle value around 46C. After installing the ThermalRight, the load temperature doesn't exceed 53C with an 80x15mm Zalman OP-1 fan installed, and about 58C with no fan installed.
