Best wb is the cascade wb (100$~) although I've heard they are on delay till Feb 04. I haven't dabbed in the gpu cooling area myself but I've heard good things about the new swiftech gpu block.
Yeah, too bad the swiftech block requires 1/2" OD to 1/2" ID adaptors... I'm sure that'll restrict flow a *teeny* bit. I'm personally looking at the Silverprop HL GPU cooler.
I'm not sure, I've never seen a cutout of it. The guy (his name eludes me now) that made the Cascade and Whitewater said if he were to chose a GPU block right now it would be the Silverprop, based on the fact it looks like one of his earlier "Hydra" prototypes .. I guess he's in the process of making a GPU block too.
I just swapped Isp's so I will need to build a page, but I have a setup that cost me about 300 including the swiftech cpu block, gpu block, and the chipset block. I have a digital temp controller running a dehumid, and I can dial my temp 😀
Silverback, love your set up! I am building a ver (VERY) similar system. Email me @ stevennoland0146@msn.com and I'll send ya some pics (or for anyone who cares for that matter). Water cooling rules!!!!!!!!!!!!!!!
