ok.......i have a 4 3/4" x 5 3/8" x 4 3/8" Cooling Cube (Copper Tube) with an 150 gph 1048 eheim, maze 2.
this system is not cooling my athlon xp 1600 oced at 1880+ too well. its at 52 to 60 C with case temps of 32 to 38 C.
i have a small cpu fan (was cooling my duron) on the radiator, not putting too much air out of it.
there are many weak components in my system. the pump is slow, maze .......couold probably do better there too.
but i have a feeling that its mainly my radiator's fault. the water gets hot and stays hot, radiator warm. i just dont think this radiator is good enough.
what do you guys say.......would a little toyota radiator do better, or some expensive radiator from dangerden.com.......or maybe i dont have enough air circulating on it (my little cpu fan on it doesnt do the job maybe).
even thought the temps are ok....machine runs fine, its still a bit high considering thi is water cooling.
i am thinking to add a 120 W peltier. this would definitely make it cold for the processor. i wonder though if my radiator can put out all the extra heat coming from the extra 120 W from the peltier....if it performs like aircooling right now, with the cpu by itself.
can you guys give some opinions here about radiators and importance thereof, pumping power, etc? i know there are many of you that really know this stuff and can discuss it profesionally. it would be very helpfull
thank you
My Rig:
Athlon XP 1600 @ 1880+ LOCKED 160x10(i think thats the official multiplier)
GeForce4 MX 440
IWILL XP333
512 PC 2700 Samsung Cas 2
Water Cooling
CPU: ~50 - ~60
Case(case is uncovered in my room, with no fans on it): ~32 - ~39
all this in the hot climate of Florida, with no AC in this room, just a ceiling fan.
a
😉🙁😱:disgust:😀:|:Q😀
thank you
My Rig:
GeForce4 MX 440
IWILL XP333
Water Cooling
CPU: ~50 - ~60
a
😉🙁😱:disgust:😀:|:Q😀
