Best walk around lens for my 30d for around $500 +- $50
alfa147x
29,307
Thats about it, I do like heavier lens's
thanks
~ alfa
:cookie:
Also
what other manufacturer's lens line compares to canons L's ?
Kelvrick
18,422
The usual suspects are the Tamron 17-50 and 24-70, depending on if you want wider or the reach. 17-50 should be found for like 400, 24-70 closer to 300.
The 17-40L is nice, but a little slow and restricting in its range for me.
If you want a much larger range, then you have the sigma 18-200 OS and the tamron 18-250. The only comparable L I'd say is the 24-105 f4, but thats double your budget.
randomlinh
linh.wordpress.com
sigma 30mm if you don't mind being confined to crop bodies (which IMO isn't a bad thing. they should always have a cost advantage. it's not like they're bad cameras).
but primes are very specific.. heh.. the 17-50 tamron is good, but a bit noisy IMO. The sigma 18-50 is worth a look, I liked mine (original non-macro), but wanted the prime more.
The canon 17-85 is worth a look too. I'm not a strong fan of it, but it's versatile.
As far as "L" equivalents... the Sigma EX (w/ HSM) line would probably be it, the ATX Pro from tokina (but only in build, they don't have USM/HSM). Not sure about others.
pennylane
6,077
What about the "L" quality are you thinking of specifically? Glass? Build quality? USM?
The Tamron 17-50mm has great optics, but only "good" build quality and no ultra-sonic motor.
alfa147x
29,307
glass
Jawo
4,125
Just be like everyone else and get the Tamron 17-50. Its my primary lens and love it, especially the constant f/2.8! Its nice and wide angle, excellent glass, and the petal lens hood is included for $450 new from B&H.
The Canon 17-85 suffers horribly from CA and the pincushion effect.
pennylane
6,077
If I learned one thing from my elementary school teachers, it's that you should ALWAYS give in to peer pressure :thumbsup:
alfa147x
29,307
what is your take on the
Canon EF 17-40mm f/4L ?
The aperture seems a bit slow but looking back to my pictures from my 18 - 55 kit lens 90% of my pictures are take an f/8 ish
PowerRanger
276
If you don't take too much wide stuff, maybe the Sigma 24-70 f/2.8? Reviews says its IQ is on par with canon's own 24-70 f/2.8 L. Its also fairly big and heavy. :p
http://www.photozone.de/Review...ab-test-report--review
If you like a more traditional FOV, the Tamron 17-50 f/2.8 is a widely accepted performer.
http://www.photozone.de/Review...on-test-report--review
There's also the new Sigma 18-125 f/3.5-5.6 OS (image stabilization), but there are not many official reviews for it yet I don't think. This lens would be the best walk-around lens in terms of focal length, but its IQ would probably be lesser than the above two if its anything like the original non-OS version (pretty average).
Regarding the Canon 17-40 f/4 L, if you don't mind the short focal length, this would be my pick.
pennylane
6,077
SLRGear (you should really check that site out...) says:
Chromatic aberration is moderate at 17mm, very low at 24 and 31mm, and then rises again for large apertures at 40mm. Vignetting is remarkably low, less than 1/4 EV at all apertures and focal lengths, almost non-existent at apertures of f/8 and higher, at all focal lengths 24mm and above. Geometric distortion is a little higher, with about 0.7% barrel distortion at 17mm, although this decreases to only 0.1% pincushion at 40mm. (Again, note that these figures are when used with an APS-C size sensor: Full frame results would doubtless be worse.)
alfa147x
29,307
wow sounds good, thanks for the link
I did do some research and seems like the lens im looking for
Any one have any complaints from a 1st hand use?
pennylane
6,077
For what its worth, I'd still go for the Tamron 17-50mm f/2.8. Going to 50mm is a big deal for me, since that gets to the wide-end of portrait range. The f/2.8 helps with low-light situations.
If that's not a huge deal for you, I guess the Canon will work. It does seem noticeably more expensive. I imagine the image quality is better in the overlapping range though.
themisfit610
1,352
The 17-40 F/4L is amazing. I use mine _all_ the time.
If you really want flexibility, and surprisingly good image quality for cheap, then the Canon 28-135mm F/3.5-5.6 IS is a really good choice.
http://www.fredmiranda.com/rev...0&sort=4&cat=27&page=2
I cut my teeth on this lens (a worn out, dirty old copy that's been to Burning Man 5 years in a row ROFL), and really appreciated its flexibility - along with a tired old 10d.
That being said, when I took the plunge and got a Rebel XTi, I never looked back once I got the 17-40 F/4L. I missed the zoom range, but the wide angle end and the L quality really won me over. I took care of the telephoto element later with my 70-200 F/4L IS, but that was a little too expensive heh...
I don't like third party lenses because of their (usually) sub-par focusing, and poor resale value. Buying Canon lenses is always a safe bet :)
~MiSfit
