Best Video Card For i3 530
Bubbleawsome
4,834
1,204
If you know you will have more money later I would get a solid 550w or so PSU and a r9 270/270x. CPUs are a bit out of the budget right now. I'm am surprised that the i3 is pushing bf4 though, I didn't think even an i3 4340 would do that. :/
nwo
2,308
What are the prices of the card options that are available to you?
I would say just get a GTX 750 Ti and get it over with. No PSU upgrade needed. It might be a little too much for your CPU, but that leaves you with the option to upgrade to an i5 or i7 without having to upgrade the GPU again.
skipsneeky2
5,035
If you love applying tons of AA in games or plan too, any card would work with that i3 530 technically .My old i3 2100 delivered a higher minimum framerate at lower resolutions with the right settings then my gtx770 does at 1080p ultra including 4x MSAA minus motion blur in BF3.
Depends if you want max quality or max fps, figured I would throw a extra bone out there.
Insert_Nickname
4,971
1,692
ok thank you all but can i put gtx 660 too??
You could, but your CPU is going to bottleneck that 660 making it kind of pointless. You will not believe the additional performance the 750TI already brings to the table coming from the 210...
That is exactly why I like the 750TI for such cases. Great performance, coupled with not needing a 6-pin connector.
Have a friend who just replaced a HD5770 with one. Over twice the performance with lower power consumption...
lehtv
11,897
74
i5-4570/4670 $200
B85 chipset board $70
2x4GB DDR3-1600 $70
GTX760/GTX770/R9 280X $250-$330
Reuse hard disk $0
500W PSU $60
Reuse case $0
This only makes sense if you intend to run a graphics card as fast or faster than GTX 760. Below that, an upgrade to a used i7-870 would do the trick.
Insert_Nickname
4,971
1,692
i5-4570/4670 $200
2x4GB DDR3-1600 $70
Reuse hard disk $0
500W PSU $60
Reuse case $0
Agree. Since your i3-530 uses DDR3 too, you could perhaps reuse what memory you already have. Get a mainboard with four DIMM slots, that way you have an easy upgrade path for later. The performance difference between 1333MHz and 1600MHz is pretty small, especially when you're not using the IGP.
While not strictly necessary for a gaming system, you might want to consider fitting some form of SSD in there.
nwo
2,308
I honestly would not recommend a whole system upgrade since you're not even gaming at 1080p resolution.
For $200 you could upgrade your CPU to an i5 or i7 and video card to GTX 750Ti or equivalent which would even be able to handle 1080p should you choose to upgrade to that resolution anytime soon.
crashtech
10,573
2,145
A platform upgrade would be nice, but I also think that a quad-core Nehalem would work well for another couple years, especially if it was overclocked. Also, if the OP like to have all the eye candy turned on, there is no reason not to go for the best GPU the budget will allow, and not worry too much about the CPU holding it back. If a decent enough GPU is selected, it might be reusable when it is platform upgrade time.
lehtv
11,897
74
True enough. I wouldn't call GTX 770 overkill for 1600x900, at least you won't have to worry about GPU bottlenecking. 1600x900 is 70% of 1080p.. similarly, GTX 770 is 75% of 780 Ti performance, yet the latter is completely fine for 1080p gaming with all eye candy on ultra.
wiryo990
20
well sometime i played at 1080p
wiryo990
20
So i upgrade my psu to vs450
so there is 3 option that i could pick
-R7 250X
-R7 260X
-R7 265
Which one that i pick???
SPBHM
5,058
410
translating the names to the old scheme makes it easier (no X vs no X thing),
250x = 7770
260x = 7790 OC
265 = 7850 OC
Denithor
6,298
23
Couple of questions.
1) Does your current motherboard allow overclocking? Because that i3 530 has Hyperthreading so it will behave closer to a quad than a typical dual. And, it's from the last generation of Intel chips that allowed FSB overclocking, so it's the equivalent of an unlocked chip. Should be relatively easy to get it to 4GHz or even higher, at which point it will handle most gaming requirements pretty easily (except for the few games that are heavily multithreaded).
2) What model is your PSU, and/or can you give us the amperage listed on the 12V rail(s).
If you can overclock the CPU and you have a strong enough PSU, I see no reason initially to upgrade those parts, just drop in a new GPU and enjoy some much faster gaming. For 1600x900 resolution, the 750 Ti would be nice, or you could look back at the previous generation and pick up a cheap 660/660 Ti.
wiryo990
20
1. Yes, but only at stock voltage 1.2v and its stable at 3.6ghz (p7H55-m lx)
2. My psu is corsair vs450 the model number was CP-9020049-EU
Aug 11, 2008
10,451
642
250x = 7770
260x = 7790 OC
265 = 7850 OC
So where do the 750 and 750 Ti fit in? As best as I could determine, the GT 750 is faster than HD7770 and the 750Ti should be close to the 7850. Is this correct? Even the vanilla GT 750 might be a good match for that CPU at 900p.
Insert_Nickname
4,971
1,692
The 750non-TI is about equal to the 7790, wins some, looses others. The stock 750TI is a bit slower then the HD7850. Overclocked however, the 750TI can actually take on the HD7870 in some cases...
RussianSensation
19,458
765
