Best vid. card for $100?
auveeb
48
Hey,
I need a video card for a new rig I'm working on and my budget is $100. What would you guys reccomend? So far I've got an AMD 3700+ and an Epox 9NPA+ Ultra. This would be used for Photoshop and Counterstrike.
I was thinking either the 6600GT or the 6800. All insight is appreciated. Oh, one more thing, could you link me to the vid card on newegg if you have suggestions? Thanks!
theMan
4,386
6600gt
or
6800XT
or
X800GTO
price corrolates with performance, whatever you want to spend.
these are all a bit above $100, but the by going down to $100 you lose a lot of performance.
imhungry
1,740
Something that works for photoshop only?
You said you wanted to play games? What games do you want to play and at what resolution?
auveeb
48
Cause I multitask (like 10 different windows open at a time)
and imhungry, I might ocassionaly play CS:S but I don't know what res. I'm going to upgrade in the future though. I just need an entry card
mwmorph
8,877
a used 9800pro is about $90, runs css very well and 2d quality is excellent.
toyota
12,957
you cant really multitask any better with a 3700 then a 3200. you could have used the difference in price to go towards a better vid card. a 6600 ddr2 or the one you linked to would be ok if $100 is your max.
theMan
4,386
well, just get the 6600 then. doesnt seem like you are much of a gamer, and it will be fine.
