Best valued 333 mhz cpu
Does your motherboard support Bartons? If yes, then the 2500+ or 2600+ (512K Barton versions). The XP2800+ is also priced nicely, if you want to spend a bit more.
If not, then a 2400+ (256K T-bred).
Yes, a higher FSB helps but it's not as important in the case of the P4.
The 2400+ has a higher clock speed than the 2500+ anyways. AMD pretty much rated them properly. As I said before, I'd stay put or make the jump to an AMD64 if you're itching to upgrade. Anything less isn't worthwhile.
Originally posted by: Jeff7181
Originally posted by: MRGOOCH
Isn't the fsb most important!
No. Keep what you have if you're not going to overclock anything.
He's right. You're not going to notice that much of a diff from 2400+ (266) to 2500+ (333).
Save your money or spend it elsewhere.
