Best tool for cutting window hole?
Syborg1211
3,297
26
What's the best tool? People seem to be telling me dremel, so what bit if dremel is best? Hacksaw? Chainsaw?
Crucial
5,026
Use a jigsaw. It will make straight fast cuts. Then clean up the edges with a dremel and some sanding rolls.
Whats a jigsaw you ask? Here's one at Sears.
DukeChestnut
349
dude i'm sooooo scared of tryin to cut a straight line even with a jigsaw. the only cuts i make are circle drills in predefined sizes. and cutting out factory fan grillz. i think i'd rather just take it to a machine shop and get it cut professional. i think they use a big machine that cuts it perfect (laser cut i think)
Howard
47,986
11
Cover the outline of the hole you want to cut with masking tape (draw it first with something that will show through). Then use a ruler and redraw the line. Use a jigsaw and go about 1/2" to 1/4" to the line, and then use a metal nibbler to finish the job. If you can't do it even with a nibbler, use a Dremel and a flapwheel for metal.
cockeyed
777
Here is an idea for you to think about. Buy a recessed lighting trim ring from a Home Improvement Center and use a jigsaw to cut out a hole to fit the trim ring into; they sell all sorts of them. It would not matter if the hole is not perfect, since the trim ring would cover the edge. They might even sell a clear lens to fit into the ring. You could paint the ring to match the case or other trim on the case to give it some pizzazz.
Kanalua
4,860
Go with a Dremel...more specifically, go with a Craftsman Rotary Tool from Sears (lifetime warranty) and use the metal cutting disk...cut inside the lines, then go over with a grinding bit...or use trimming to hide your ruff edges...
