- Dec 20, 1999
- 1,980
- 1
- 86
Greetings I ran out of thermal paste and will be O/C my future setup and my current DFI Ultra-D setup.
I was wondering which paste at http://www.svc.com/thermal-compound.html
Will give me the best cooling and the most longevity (in future system setups).
I plan on trying some Ram O/C and GPU O/C down the road.
With that being said it seems for the CPU / GPU AS5 over Céramique(T/F)would be a good option:
http://www.svc.com/as5-3g.html
It says it can be used on 12 cpus. All things considered I figure a 3.5 gram tube would go a long way. Then for my GPU and ram sticks what would be good thermal tape?
I will be buying the Evercool VCR-E or a Thermalright HR-05 for my chipset fan on my DFI-ULTRA-D( Chipset fan sounds like a bomb ready to go off). What else would you suggest
