Looking to upgrade my system. This system is purely for gaming, specifically for Planetside2 and BF3. Looking to maximize my bang for the buck to get good frames in those 2 titles. Not really interested in OC and prefer to run a single GPU setup.
I currently run BF3 at 1680x1050 on all low settings to get 20-30 fps which barely seems adequate. I ran the PS2 beta and had terrible frame rates ~20 or less.
I see 2 paths here..
1 - Buy a new video card and an upgraded AM3 based chip. Lowest cost for an upgrade then move to a new CPU, board and ram in 9-18 months from now.
2 - Start fresh, get an intel chip like i5 3450 or i5 3570K. This means i have to buy a new CPU, board, Ram, and GPU so the cost is a lot higher going this way.
So the real question is Will option 1 be enough of an upgrade to get solid frames in PS2 or should i bite the bullet and spend the money now?
Thoughts, recommendations?
Thanks all!!
Current Spec
AMD Phenom II X3 720
GA-MA790x-UD4P
Radeon HD 6850 1024 MB GDDR5
GSkill 2x2MB DDR2 PC2-6400 (400mhZ)
Corsair Professional HX650W 650W ATX 12V 52A 24PIN ATX Modular Power Supply Active PFC 120MM Fan
Coolermaster HAF 912 Black Mid Tower ATX Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Sound
Win 7 32
23" Monitor 1900x1200 native res
Either way I feel the sweet spot for a GPU right now is a Radeon HD7870 (~$220). I could not find any AM3 CPUs above a 965 listed at newegg, perhaps there are better ones out there?
Option 1
Phenom II X4 965 (~$90)
~$300
Option 2
Core i53570K (~$230)
Gigabyte Z77x-D3H (~$150)
GSkill 2x4GB ~($50-80)
~$700
Thanks all!!
Current Spec
GA-MA790x-UD4P
Win 7 32
Option 1
~$300
Option 2
~$700
