- Mar 27, 2007
- 26
- 1
- 0
Hi guys, I'm looking to build a new system for my brother and was wondering what would be the best gaming system for no more than $1500?
Thanks,
underground.shogun
Thanks,
underground.shogun
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
8. What resolution YOU plan on gaming with.
9. WHEN do you plan to build it?
Hi, please answer the following questions from the sticky so that we can better assist you.
1. Lite Gaming (some MMORPG's) No FPS types.
2. $1350 - $1550
3. USA
4. No "off" brands. Nothing well established.
5. No use of current parts other than a monitor; this will be a ground-up build.
6. ATM, No.
7. No overclocking.
8. I will have to check with my brother on this one. I'm not sure what resolution his monitor currently supports.
9. Within the next month at the latest.
1. Lite Gaming (some MMORPG's) No FPS types. 2. $1350 - $1550
OK, from the sounds of it, you don't need to spend anything close to $1500 to do what your brother wants.
ASUS M4A77TD $75
Phenom II X4 955 $160
G.SKILL DDR3 1600 4GB $110
XFX 5770 $160
1TB WDC Black $100 (you can substitute the Samsung F3 1TB here if you find it in stock)
LG DVD Burner $20
Corsair 400CX $50
Antec Three Hundred $62
Windows 7 Home Premium 64-bit $100
Total: $837
For mouse and KB (if he needs them), go to Best Buy or wherever and try some out in person.
One one thing that you could add that would improve general usage performance would be an Intel X25-M SSD ($225). SSDs are rather pricey, but he does have the budget for it.
ASUS M4A77TD $75
XFX 5770 $160
LG DVD Burner $20
Corsair 400CX $50
Total: $837
On the ASUS M4A77D, I noticed on the specs on newegg that the memory standard is DDR2 1200/etc. Will the G.SKILL DDR3 1600 work as well on it? Just want to clear this up before I tell my brother to start ordering parts. Thanks.
Thanks for the reply. I must have somehow copied the part down wrong. Certainly saved me a headache later on!
