Going to be playing mostly BF1942, Halo, Call of Duty. Having about 10 players. Are those games limited by 10/100 or should I upgrade to a Gigabit switch like the Dell PowerConnect 2616?
You'd be fine with one of the cheap Gigafast 8-16 port switches you can get for like $10 after rebates. Otherwise I've had good luck with Netgear and Linksys switches and routers. Its normally what we have when we setup a LAN party. Even when we had a couple of switches and hubs daisy chained together we never saw pings over 60 and this was running 16-32 people matches
