Best sustained transfer rate for hard drive?
zener
497
I need to build a PC to capture data with a sustained rate of at least 30 megabytes per second (not megabits). Any IDE hd or scsi hd configuration can handle this requirement? Thanks,
dexvx
3,899
The newer WD JB series and the Maxtor DM9 barely pass.
WD Raptor can do it pretty easily, and just about any U160 10K rpm SCSI drive.
Jeff7
41,596
20
A dedicated RAID 0 setup maybe, with the operating system on a separate drive.
AgaBoogaBoo
26,108
Yeah, you might want to go Raid 0 of an 8 mb cache drive. Raptor and 10,000 RPM SCSI drives should do it as well. Make sure to check out specs and results at storagereview.com before buying
