Best speed of RAM for my mobo cpu combo?
coremortality
118
Can I run DDR2 800 with the E6600 or should I be running ram at the same FSB of 1066? I thought I read a post here on Anandtech where people were recommending slower ram to save money.
I'm building a new system that will be primarily a work system but will also be used for mild gaming (HL2, TF2, WoW). I'm going to be using the Gigabyte GA-965P-DS3 with the E6600. I wont be doing any overclocking so I'm looking for the most solid performance possible out of the box. I plan on starting with only 2 gb but I may add another 2 if i decided to take the plunge with Vista.
Thanks.
-Eric
-edited to add additional information.
cprince
963
DDR2 800 would be okay for the DS3 motherboard. If you want to save some money, you could use DDR2 533. The different won't be much. See: http://www.anandtech.com/mb/showdoc.aspx?i=2813&p=1
It's really not worth the money if you add another 2GB of memory unless you use Vista 64-bit edition. The 32-bit edition(like XP 32-bit) can only address about 3.12GB. So you have almost 1GB of RAM wasted.
rdp6
312
I just got the E6600 with that mobo (rev 3.3) with some G. Skill DDR2 800 (was cheap) from the egg. I also got a 650W silverstone PSU... anyways, the system runs fine at stock speed (ran superpi, etc, no problems). I also checked it out at 8x400 for 3.2GHz, where it ran games, etc. just fine for a couple days until I had to get the machine to its new owner (back to 2.4GHz now).
I have read that the G. Skill DDR2 800 is troublesome with the GA-965P-DS3, so YMMV. I could run the system at 9x300, but couldn't get to 3.0GHz with the 9x multiplier. I didn't try all that hard, as I am not a habitual overclocker, and also used that retail HSF that came with the cpu.
blacklit
440
all 32-bit windoze versions can use 2gb max save 2000/2003 adv server, which can use up to 3gb using a switch.
2gb is all you'd need.
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
At stock speeds, your memory is running at DDR2-533.
Given that DDR2-667 costs the same amount, I would get this 2GB kit.
Depending on your motherboard, 32-Bit Windows can use almost the full 4GB. I'm running Vista, and it's seeing 3.7GB out of 4GB.
Blain
Does the GA-965P-DS3 have issues with "high performance" memory that's rated to run more than 1.8V?
FreedomGUNDAM
2,405
I just picked up a 2GB kit (2x1GB) of G.Skill F2-6400CL5D-2GBNQ from newegg.com for $85.00 shipped. My Gigabyte P965-DS3 (rev3.3) ran memtest for 24hours without any problems.
Roguestar
6,045
Thanks.
-Eric
You need to multiply it by 2 to account for DDR2. DDR2-533 runs synchronously with a FSB of "1066" (which is actually a FSB frequency of 266, and is quoted at 4x because it sends 4 bits instead of 1, per cycle, hence "quad-pumped"). Basically if you're not overclocking, odds are your RAM will run at DDR2-533 speeds anyway, but seeing as a lot of good deals are around, if you pick up some cheap DDR2-800 you're set even if you do later decide to overclock.
Not for months now. I have the S3 which is apparently rated the same at 1.8V, but I've been running my Crucial memory at 2.2V and ~900MHz for months now, with no problems. First thing I did when I put it together was put one stick in, boot and change the VDIMM and then put the other in and away we go.
