Best speaker for 100$ less?
go for a 2.1 set-up or the poorer quality speakers wont take advantage of your audigy 2. if i were you id save up for a set of klipsch 2.1 i have 'em and am very happy if not i had some logitech z3s before this set and i was happy w/ that set too they are only like 50 american dollars so you can save a few bucks
Erm, I doubt newegg is the place to shop for speakers. Best bang for the rupee can prolly be had slapping 'em together yourself with schtuff from partsexpress or such. They also have pre-assembled ones. Or perhaps consider refurbished or used. Personally, I think a subwoofer on a cheap-o set is just an attempt to make up for lackluster or non-existant woofers in the mains, at best, and gimmicky at worst, and should only be added to enchance an already adequate set -unless you are just a bass monkey and don't care about clarity.
