Best Soundbar for $$
stormdlp
Title says it, any ideas? Got a crappy LED TV with NO sound pretty much, but tired of wiring surround sound.
Dont wire the surround sound. If you already have a receiver and speakers then use them. You can setup a 2.0 or 2.1 setup (assuming you already have the gear?). Soundbars suck
I have used sounbars and the lower end ones do pretty much suck. Better than built in speakers certainly but still extremely lackluster. It sounds as you already have some equipment. A basic 2.0/2.1 set-up will be way better than a cheap sounbar.
You could go for a 2.1 setup which could be fine but if you want a good sound bar I would suggest looking at the Energy, Polk or PSB, Klipsch sound bars. They are not cheap but they do a good job. Sound and Vision recently reviewed some higher end sound bars.
That one looks good. I made the mistake of an impulse buy with an LG with bluetooth, and have been very disappointed in the fullness of the sound. It's hardly better than the tv speakers alone.
On the other hand, we bought a cheap tv (Element) for my daughter's room, and it comes with a built in JBL soundbar, and the sound is outstanding. Of course, the picture quality is weak, but the sound is awesome for a tv.
Yeah the Polk ones were by far some of the best technology at the time. All the others rely on attempting to reflect the sound off a floors/ceilings/walls to attempt to make the sound appear to come from the side or behind you. Polk's system used straight up wave interference to cancel the audio sound from the other channel so that when something was in the rear right, they canceled out the frequency waveform from going to your right ear with a second driver spaced approximate the distance between human ears and 180 degrees out of phase so that when the signals combined when they hit your ear, they cancelled, resulting in the sound only going to your right ear and not even heard in the left.
I recently just moved to an Apt where 5.1 solutions were not applicable. I got this sound bar based on some research. http://www.amazon.com/Sony-HT-CT660-46-Inch-Wireless-Subwoofer/dp/B00C25I5TE/ref=sr_1_1?ie=UTF8&qid=1375208643&sr=8-1&keywords=sony+660 it is really good. There are some stupid functionality issues that I am not happy with (HDMI input locations), but they are minor and overall performance is good.
However, I was told that this was one of the best for the money. http://www.amazon.com/Yamaha-YSP2200...ds=yamaha+2200
Good luck.
