best sound card for Vista?
Sniper82
16,517
I am using Vista 64bit and my onboard sound is a little flaky. Whats the best card for Vista as far as support/compatibility?
Mem
21,476
13
Depends what you want it for, gaming wise I don't have any problems with my Audigy 4 sound card and it does seem to have less problems then the X-FI series(however latest X-FI drivers seemed to have fixed most problems).
There's really not a best sound card for Vista,just one that works and you are happy with.
nerp
9,865
105
I'd steer clear of creative labs, but I'm an audiophile snob. M-Audio makes nice stuff and they seem to have Vista 32 drivers out for their Revolution 5.1 and Audiophile 2496. 64 bit drivers are supposedly forthcoming.
Arkaign
20,736
1,379
Vista actually makes high-end audio hardware less important than it used to be. AFAIK, the way it processes audio basically bypasses a lot of the hardware-based acceleration (a la EAX) on many 'premium' sound cards.
Of course, that's just what I've come to understand from cursory research, and I could be way off the mark.
I 2nd the M-Audio suggestion, I've used many of their products with outstanding results.
oynaz
2,449
M-Audio make good sound cards, but you pay for their good recording capabilities. If you do not do a lot of recording, they are a bit of a waste.
Mucker
2,833
X-Fi Extrememusic/Klipsch 2.1 Promedia working great for me in Vista x64. Very easy installation.
1. Un-install onboard sound software, disable onboard sound in bios, install X-Fi card
2. Install newest driver from website
3. Install newest Console launcher from website
4. Install newest media source from website
5. Get or have a good set of speakers
6. Enjoy the sound.
