Best solution to bandwidth problems in video cards?
Muerto
1,937
Hello people,
What do you guys think the best solution to the memory bandwidth problems in video cards like the GF2 is?
Personally I think that the memory bus width has to be increased to 256 bits at least. That would give a GF2 over 10 GB/s of bandwidth. We could then get a lot closer to the theoretical fill rate of 1.6 Gtexels/s.
I hope that nVidia doesn't just put 200 MHz DDR SDRAM on the NV20, that's only 6.4 GB/s, as much as the Radeon256. The NV20 wouldn't really be worth buying if that were the case.
I think that Bitboys had the right idea of using embedded DRAM in their Glaze3D. It had a 512 bit memory bus! Unfortunately we wont be seing that anytime soon. :(
Anyway, thanks for your input. :)
IvoryGrail
710
But also keep in mind that the NV20 might use a hidden surface removal technique which would greatly reduce bandwidth. Add the rumors of Z-buffer compression and others, 6.4 GB/sec is not all bad.
Goi
6,766
7
Memory isn't going much faster overall, so new algorithms and techniques have to be applied to reduce memory bandwidth consumption.
A 256-bit memory bus isn't really feasible for external memory, as it could be really expensive. Embedded DRAM could alleviate some of the problems we have, but its potentially only a temporary solution as you can't embed too much memory into the core without increasing the die size and cost.
