First off, I'm sorry if this has been answered somehwere else. I took a look at another thread comparing the X2 and Opterons, but the discussion centered around the vast cluster # requirement of the cluster in question, so I thought I wouldn't mess up that guy's thread with my question.
I am looking at building a small 'test' cluster for testing out applications (specifically FDTD code for rigorous electro-magnetic calculations) which my research group will then take to the campus computer cluster (which we hear is drastically under-used). I'm interested in less than 10 nodes, however, as we have only about 5-9k to spend on the entire thing.
Specifically I'd like to know price/performance how an X2 cpu compares to an identically clocked Opteron (other than the 25% cost difference). Space-wise, I know rack-mount is the way to go, but if we're talking 8 processors, what's to keep me from getting 4 slightly cheaper dual-core SFF computers like Monarch's Hornet Pro? (SFF mobo's are now capable of 4G RAM)
Also, I know Windows is pratically never used in clusters, but there are a few MS apps our group uses (Matlab, for instance) which might benefit from some distributed computing in addition to the MPI code being specifically developed for a partner to run on their own cluster. Can someone (or everyone perhaps) tell me why linux is always used besides the cost factor and a little less overhead? We don't employ any full-time person fluent in Linux so every other year or so the group would have to elect a local 'guru' to learn how to operate our little 'test' cluster and maintain it. We're not a Math department where everyone speaks linux and it takes a little effort to veer away from the ubiquitous MS beast. Aren't all cluster programs custom c++ (or similar) code? In my limited understanding, I don't see why a c++ program couldn't be developed on one cluster of a particular OS and compiled/run on another cluster with a different OS. Hence, unless I can be convinced otherwise, I guess I'd initially pick the 4 SFF computers as above (X2 4600+ & 4G RAM) for 8 nodes. If running the code on another larger linux cluster required development of the code in the same OS, then how about 2 of the boxes being linux (for the actual project to be ported to another cluster), the other two running windows for other distributed MS apps using, say...MPICH as the middleware (compatible with both OS's so all 4 could be used?).
I see this being the most flexible solution for a small cluster with much more staying power in our group as it could be used for many other things from the windows machines. But I'll be the first to admit I don't know much about clusters, so pipe in! 😉 Tell me why it won't work and/or show me a better performance/$ system which could still be used by the average computer novices that roam through our group every 4 years long after the initial charter for this cluster is done and I'll capitulate.
P.S. - if windows can be used, I'm guessing it'd have to use a server OS (i.e. not XP)? Or is that only if all the nodes have to talk to eachother? I'm not the one setting this up, but I guess I'm the current one in the group that knows the most about hardware in general...just not the ins/outs of what makes the best hardware for clusters.
