Best "silent" or quiet power supplies
timg11
7
In the past I have purchased PCP&C Silencer supplies, but they have not really been that quiet. I notices that stock Dell systems are often quieter.
I would like to find a high quality PS that is in the range of 400 watts, that is not really expensive. This is for a audio recording studio application with a mid-range Core2 CPU and 2 SATA HD drives.
I found this page http://www.silentpcreview.com/article699-page1.html, which has some recommendations, but a lot of the reviews are 2 years old.
What are some currently available supplies that are truly silent (or at least very quiet), that you have had good experiences with?
burek
190
the Seasonic and Corsair (which is made by Seasonic) are the quietest ones that i know of
SparkyJJO
13,357
7
Agreed here. For a lower cost the FSP units around the 400W range with 120mm fans tend to be fairly quiet running as well (maybe not as quiet as Seasonic/Corsair, but still not bad at all). The 400W FSP I put in a customer's PC is just a low hum.
SinfulWeeper
4,567
11
I cant hear my Aerocool ZeroDBA 620 watter under full load. Loudest part in my computer under normal operation is my hard drive rated at 3.2 bels.
Turn on my DVD-Rom and my system becomes a loud monster. I need a replacement DVD-Rom :|
Rebel44
742
IMHO Seasonic, Corsair or Enermax Infiniti - my experience is that these are very quiet and 80%+ efficiency.
TourGuide
1,680
I'll second this recommendation. I have the PC Power & Cooling Silencer 750 and Silencer 750 Quad. I could recommend this supply as a GREAT quiet supply with amazing specs.
Originally posted by: TechBunny
My pcp&c PSU is very quiet...
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
PCP&C's Silencers aren't "silent." Maybe only compared to Turbo-Cools, yes, they're quieter that those.
Quietest power supply: Koolance Liquid Cooled 1200W. Hands down. :D
Conky
10,709
Better be careful or people will notice that you always knock the PCP&C brand. :p
BTW, Silencer 750 Quad is $170. How much is that 1200W psu? ;)
Zepper
18,998
Hey timg11,
Welcome to the AT forums.
The PSUs at the link in my sig are quiet and on sale thru midnight tonite. How serendipitous! :D
.bh.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
LOL....
I don't always knock PCP&C. I actually like PCP&C very much. I just like when people say untrue things about PCP&C that put them in a better light. PCP&C units can stand on their own laurels. They don't need fan boys and phoney "power supply myths" to make them more attractive.
krotchy
1,942
Well I guess I can also help chime in herre.
Seasonics and Corsairs (Seasonic made) are indeed very quiet and a good choice (My favorite Seasonic is the S12+ 550W), however these are all more power than you need.
Another overkill option for silence is the Zalman 600W Heatpipe PSU. According to jonny its a rebadged Fortran unit, and a good one at that.
http://www.jonnyguru.com/revie...s.php?id=46&page_num=4
Also the Antec Earthwatts 430W/500W PSU is a good choice, and probably your best bet for the price. They are also rebadged seasonics, and aside from being ugly (who cares) are quite good.
http://www.jonnyguru.com/revie...s.php?id=51&page_num=4
Noubourne
751
I would say Seasonic too, but since you already had a 750 Silencer, you have already had a Seasonic and you think it was too loud, so I'm not exactly sure what to tell you.
I can tell you that my M12 700 is inaudible over my video card. That ain't saying much though.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
There's a big difference between a Seasonic with an 80MM fan and a Seasonic with a 120MM or larger fan.
Of course a PSU with an 80MM fan is going to be louder.
bryanW1995
11,144
32
I just ordered a corsair hx520w on newegg. I'll let you know how it is.
secretanchitman
9,352
23
my enermax 500W (NOT the 620W - those are bombs/high fail rates compared to the 400 and 500W versions) is pretty darn quiet. just one 120mm fan. it is $110 on newegg, but its really efficient/reliable/good for the money.
TourGuide
1,680
What would you say are the things you like and dislike about PC Power & Cooling units Jonny?
I have always gravitated to them for their performance and specs. Their noise hasn't been great, but I have never had a power related problem while I've used their products and I've gotten absolutely fantastic support from them when I needed it.
This latest unit (Quad 750 silencer) has been the quietest and best unit I've had so far.
LOL....
Golgatha
12,379
1,004
If you don't mind voiding a warranty, get any descent single 120mm fan PS and replace the fan with one of these from Newegg.com.
I have a HTPC with one of these inside the power supply and an Arctic Cooling Freezer 64 on the CPU. That case is dead silent. My Playstation 2 makes more noise than that PC does and the Playstation 2 is behind a glass door.
KeithTalent
Administrator
Nov 30, 2005
50,231
118
My old 500W Seasonic was dead quiet; I never heard the thing. Though now that I think of it I never really hear my new Thermaltake PSU either. :confused:
KT
Zepper
18,998
Swapping the fan out of a PSU can be a dangerous thing unless you really know what you are doing. Most PSUs are already set up too far to the quiet side and to little to the "keeping the PSU cool" side. The Scythe fan mentioned above moves very little air even at full speed - consider what it might push when controlled by the thermal fan control in the PSU (if it would even start at all). Now if you set it up to run full speed 24/7, then that might be OK.
The Seasonic PSUs with 120mm or larger fans are known for their quietness. Most other good PSUs with 120mm or larger fans would be plenty quiet enough for all but the real noize nutsos.
Most find the Enhance ENP-5150GH or 5140GH plenty quiet.
.bh.
