Best SFF solution for 2x 4k + 1x 1080p
Mark R
14
I'm looking to build/procure some workstations for work. They will need 2x 4k monitors + 1x lower res (probably 1080p) monitor.
Ideally, the main unit should be SFF. It won't need any optical drives, etc.
However, a midi form factor with low profile graphics card would be a reasonable alternative.
I don't need particularly much 3D power, as the work will be mostly 2D - but most of the SFF/LP solutions I've come across max out at 1600p or won't support triple displays.
Am I unrealistic with my requirements? I'm just trying to keep space demands down, as these workstations will be for telecommuting.
NTMBK
10,237
5,019
A Kaveri APU will drive a 4K display and a 1080p display- that plus a low-profile card like the R7 240 should do the trick.
Insert_Nickname
4,971
1,691
That's likely the cheapest solution. Without getting into anything too exotic. Just take care what mainboard you pick, not all FM2+ boards have Displayport, with HDMI you're limited to either 24 or 30p. If that's an issue.
